1 - 13 of 13 Posts
Hi guys,
I got a problem, we have just bought a new Jazz for my girlfriend and on cold mornings (most of them) we find the whole of the windscreen frozen ON THE INSIDE and once I got in the Jazz after a cold morning I found pools of water in the handle section (probably from the car defrosting inside). I could understand if we bought an old second hand car with bad seals, but this car is just over 1 month old.
My girlfriend took it back to Honda today and they said nothings wrong, and came up with some strange excuses.
They believe that because the car has such good seals that any moisture we bring into the car (wet clothes, hair, our breath....yes they said that) it stays in the car and therefore freezes overnight.
Has anyone experienced this before, on either their Jazz or any other car? If so any way to stop it happening as it takes her 20mins in the morning before she can set off to work.
Cockup Specialist
Yes if you have climate control or something similar then leave it on permanent or you'll get condensation build up in the car...
Thanks guys for the quick response... not too happy with buying a brand spanking new car and having to defrost the inside within a month of buying it. Can't win them all I guess.
Will try and run the air con for a while to dry out the moisture.
Cockup Specialist
Its the way Honda work.
On the civic climate control hardly draws any power as its on a part time duty cycle.
And we do get condensation if you leave it off.
The AC also gets bacteria buildup and stinks if you leave it off.
Their is also a chance you have a seal gone somewhere... door sunroof window windscreen or something.
Couldnt figure out why the hire car I had was damp until I noticed the sunroofs werent closed properly by the previous driver.
Exact same thing happens to me - usually on cold mornings. Once or twice I have had a sheet of ice on the inside :eek:.
That explanation you were give is the same one I've had from a variety of sources. Basically, newer cars have much better sealing so air doesn't circulate in or out. Hence, when condensation builds up (which it will in any car) it will stay in the car rather than "leak" away. Couple this to a cold (e.g. -5) night and that condensation on the windscreen cools down into ice.
Also, if a seal has deteriorated, then this is LESS likely to happen because the deteriorated seal allows condensation to escape - it's the fact that modern cars are sealed so well that is why this happens.
Does that mean if i was to buy a new car, whether it be a jazz civic or other and i went on a long enough drive that i would eventually die from lack of oxygen if i left the windows up :p
..... gotta say does sound like your getting mugged off a bit, easy to tell tho, take one of the door seals off.... poke some holes in one (they only cost a few quid to replace) should it freeze again , then you know there s another problem
..... i personally cant see how someone can breath that much in the car that there is enough condensation to freeze over the wind screen.... unless your up to something else in the Jazz you dirty do ;)
........... when the H Jazz is rocking.... dont come a knocking
Hi guys,
Try cleaning the windows and leaving the heating on for around 30 mins at full power and at hot.
I dont have air con in my type r, and any car ive had in the past ive very rarely used it.
Maybe something like rain x anti fog could solve your problem.
You might find the car mats are wet and produce condensation on the windows when they begin to dry out.
Lol :p
Kids use a lot of space
If it's new it may just be dampness condensing on the glass.
Just in case check the boot well (where the spare wheel lives if fitted or under the false floor) if it's wet you've found the problem. Also check the rear and front floor just in case. If everything is dry, it should dryout and be fine (any puddles and you've got a leak!). Not common, but possible given the cold and wet weather recently.
Hello,
We had the same problem with the jazz when it was new. Explained to the dealer what was happening and they found that the small rubber outlet "dump valve" on the underside of the HVAC unit under the car was incorrectly fitted (bent upwards), and this prevented the moisture that the aircon removed from the car, exiting the car. This moisture stayed within the system and caused excessive condensation which then froze over.
1 - 13 of 13 Posts
