1 - 9 of 9 Posts
Hi just wondering if its possible to get the geometry settings you use for a fast road set up on the fn2 type r ?
Regards
If I set up the frs with springs and camber kit etc will this have to be done again when I replace my alloys with aftermarket ones with a different width and offset ? Thanks for the help
Imo no but ive been told im wrong before (still think im right)
Sent from my GT-N7000 using Tapatalk 2
Haha fair enough. Logically I'd think it makes a difference due to tire width and positioning altering ??
Cockup Specialist
Camber castor and toe will be exactly the same no matter what wheels you put there.
The problem is the wider front track means the turning circle of the front wheels change slightly.
Inside wheel turns a tighter circle than the outside wheel.
They should each follow concentric circles which is a wheels track apart.
So if you increase or decrease the wheel track....you change these turning circles
How much of a difference that would make to the toe settings I wouldnt know.
http://www.carparts.com/alignment.htm
Right ....thanks :) guessing my best bet is to get it done again then or have I completely missed the point ?
Cockup Specialist
Depends.... if they use off the shelf setting for all civics, then nothings gonna change.. so no point.
If they tune all cars as necessary then yes.
Best thing to do is throw the question at them and see if they use the same settings for all... no matter the track (& if they think it really matters if the track is 30mm wider)
1 - 9 of 9 Posts
