1 - 12 of 12 Posts
So I pull into the Shell garage to refuel pull the fuel cap lever and my fuel cap wont pop open.
Tried several times pulling the lever to no avail, had to eventually ask someone to pull it open simultaneously as I pulled the lever then I got it open.
Will have a closer look when its daylight.
Has anyone else had this problem. Is it a case of using some WD40 ?
Thanks adsbeau will check that out. Just wont spring open and I cant keep asking someone at the petrol station to help me open it lol.
Easy to fix ? Or return to Honda as under warranty.
Thanks again
Cockup Specialist
I had this a couple of times but managed to pull open the cap with my fingers.
I came to the conclusion the rubber tether was snagging.
Made a point of making sure it wraps around the fuel pipe properly without any twists.
Never had a problem since.
I had this fault in 2006 on my brand new 1.8 ex. Took it back and they sorted it. No problems after. while I was there someone else was there with the same problem so it may have been a problem with the earlier models.
I have not got this issue anymore, my tether has rotted away and snapped in 2 places.:(
Its now 2 weeks im oppening my fuel cap without leever as have got same problem, i use some preasure pulling the cap and then it opens, i know its not the best way to open but i havent got time checking whats up, i think cable snapped or came of because when i pull leever i cant feel anything
The Dugs Baws
I had problems with the cap opening on my derv and thought it was the cable, but it was the spring that needed opened up a bit with a screwdriver,
1 - 12 of 12 Posts
