Hello all,
As I expected we have had no issues with the Civic at all, but today it finally decided to give us some head-scratching issues.
Everything worked fine as I was on my way to the car wash. Not the automatic one, they used a pressurised washer. I also had them vacuum and clean the interior. I was there during the whole thing and nothing funny was going on.
As I was leaving I immediately noticed that the fuel gauge needle is all the way to the bottom and the orange warning light is flashing just below the indicator.
I tried the simple things like disconnecting the battery for 10 minutes but it did not help. Next I will check the fuse #10 in the cabin fuse box, but if that checks out ok I suspect the problem is with the fuel sender unit not getting its message across. They might have tugged a wire while vacuuming, but not being familiar with the location and wiring of the sender unit I am just speculating at this time.
Anything else I might have forgotten? Any particular tips regarding the sender unit troubleshooting? I am off now to search for the location of that thing, I guess it should be under the back seat.
Thanks!
Thanks!
