1 - 11 of 11 Posts
Hi All,
I put some diesel in my 2008 Civic 2.2 yesterday and the fuel guage didnt move and is showing nearly empty still so I have a problem. Am i right in thinking the first thing to check would be if the fuel pump float has got stuck ? is the fuel pump under the center console ? is there a guide i can follow anywhere to help remove it ?
Thanks,
Scott.
This sometime happens to me doesn't see I had petrol in. I have set reset trip A on refuel and when it happens it doesn't reset.
My guess was something on gas station gun and ring on car. Try going on different station to see before removing anything.
Discussion Starter · #3 ·
thanks for the fast reply. When it happened I went straight to a different petrol station and put more fuel in but it still didnt register on the guage. Allthough the digital reading of how many miles is left is still going down.
Discussion Starter · #4 ·
Just to add I only wanted a little bit of fuel to last until pay day which is monday so i only put £5 in, then another £5 when nothing showed, then another £5 at a different garage. Could it just be the small amounts causing it not to register or is that unlikely ?
Maybe. Not sure. If milage isn't cahnged also then it didn't register anything. Mine happend also on small amount. Try £10-15 and see. Fuelntank is under seats and pump is under central console (handbrake) as I remember
Ante is correct for the fuel sender but before you remove the center console/handbrake you might want to check fuse #10 is okay.
MY13 9G Civic Auto
Sorry to hijack thread, but how do you set "trip A" so that it resets mileage when you re-fuel. Didn't know it was possible.
1 - 11 of 11 Posts
