1 - 1 of 1 Posts
Hi all,
Over the last week or so i've developed a 'racheting noise' when under power.
there is no noise when idling, then it starts around 2k rev as a slow knocking (maybe 3 knocks a second) and then speeds up through to around 3k revs. as soon as I lift it stops, before starting again in the next gear the same way. I can no longer hear it once I'm into 4th but by then the engine/road noise is up over the noise of the noise.
I can see anything loose under the bonet, cant see anything rubbing against the fans and the belts all look fine.
Any ideas
cheers in advance.
1 - 1 of 1 Posts
