1 - 2 of 2 Posts
more torque than the mrs
Under bonnet fuse box (petrol)
1. Main fuse battery/EPS
2. Headlight Main/Ignition switch main
3. VSA motor/VSA F/S
4. Option main
5. i-Shift
6. Power window main
7. MG clutch
8. Throttle control relay
9. IG power
10. IG coil 1
11. IG coil 2
12. Rear defroster
13. LAF sensor
14. IG coil
15. Sub fan
16. Back up
17. Interior light
18. Main fan
19. Blower
20. Oil level sensor
21. Horn, stop
22. Hazard
23-28. NOT USED
Interior fuse box (petrol)
1. Power window
2. Fuel pump
3. IG1 ACG
4. ABS unit
5. Heated seats
6. Front fog lights
7. Daytime running lights
8. IG1 start
9. ODS
10. Meter
11. SRS
12. Right headlight high beam
13. Left headlight high beam
14. Small lights (Interior)
15. Small lights (Exterior)
16. Right headlight low beam
17. Left headlight low beam
18. Headlight high beam main
19. Small lights main
20. Rear fog light
21. Headlight low beam main
22. Shifter
23. Start signal
24. Sunshades
25. Door lock
26. Driver's power window
27. NOT USED
28. Rear accessory socket
29. Accessory
30. Front passenger's power window
31. Headlight washer
32. Rear right power window
33. Rear left power window
34. NOT USED
35. Accessory/radio
36. IG2 HAC
37. Daytime light
38. Front wiper
Under bonnet fuse box (diesel)
4. Option main
5. Glow
7. MG clutch
8. IGP2
9. IGP
10. NOT USED
11. NOT USED
12. Rear defroster
13. NOT USED
14. NOT USED
15. Main fan
16. Back up
17. Interior light
18. Sub fan
19. Blower
20. NOT USED
21. Horn, stop
22. Hazard
23. Fuel heater
24. ISV
25. Fuel heater monitor
26. PTC1
27. PTC2
28. PTC3
Interior fuse box (diesel)
1. Power window
2. Fuel pump
3. IG1 ACG
4. ABS unit
5. Heated seats
6. Front fog lights
8. IG1 start
9. ODS
10. Meter
11. SRS
20. Rear fog light
22. Shifter
23. Start signal
24. Sunshades
25. Door lock
27. NOT USED
29. Accessory
34. NOT USED
35. Accessory/radio
36. IG2 HAC
37. Daytime light
38. Front wiper
Fuse list diagram from Civic Manual that comes with the car:
1 - 2 of 2 Posts
