1 - 20 of 54 Posts
Can Some one tell me what the best gear box oil is to use for my 07 ctr or should I just buy off my honda dealer
I recently changed to Redline MTF and the difference compared to Honda MTF3 is like chalk and cheese. Cold gear changes are really smooth and get better when warmed up. Honda oil just made every gear clunky even when warm.
I would recommend Redling MTF off opie oils website ?
Reactions: StuK
I can say I also put redline in mine and it's like a different car. Never crunch or miss gears anymore smooth even in the cold.
Well worth doing. Was a bit of a pain but with funnel and some tubing changed it myself in about an hour.
Cockup Specialist
+1 ...redline in the diesel worked a treat too.
Massive improvement over what was put in there before.
JAPFEST Event Organiser
Amsoil is another popular oil to go for.
Can one of you guys confirm that there is no whining in 2nd gear when used with Redline? Just want to clear up all this malarky being said on forum about it?
Cheers guys
aka Paul
I've recently found out that Millers Oils EE10w40 Semi-Synth NT (engine oil with MTF-94 spec and NanoDrive tech) is suitable so I'll be trying that next. Currently using Amsoil MTF which is great.
You sure that's ok to use Revs?
Oilman said there wasn't anything suitable with nanodrive tech for our boxes yet.
aka Paul
Reactions: TaKeN
aka Paul
If you do, let me know how you get on please :) I'm not due for a GB oil change for a bit yet.
Discussion Starter #18
Is this oil a thick oil or thin oil my honda dealer says you can only use Hondas own as its very thin stuff? There just after my money (I do work for the company that has the honda dealer ship)
regrets his username
Thin oil I assume as it warms up quicker than the mtf3, im using the red line as I found hondas awful in winter
aka Paul
In theory any oil meeting MTF-94 spec should be fine :)
1 - 20 of 54 Posts
