1 - 13 of 13 Posts
· Premium Member
hi all ive noticed that when i change gear in the car it feels a bit notchy ie not very smooth and the odd time a bit difficult to put into gear any advice thanks:(
· Premium Member
I had this problem on my last civic, dealer advised me that they all do this and there is nothing wrong with it.
There are a few threads on here from people who have had similar problems and their dealers change the gear synch. Think it was mostly on type'R though.
Reactions: smig64
· I'LL NEVER WALK ALONE
there is a bulletin about it and it's not just the type R 3rd synchro....
Reactions: smig64
· Premium Member
Discussion Starter · #5 ·
ok thanks for the replies will keep an eye on it
Reactions: smig64
· Registered
The only bulletin is about pebbles/dirt blocking the gearshift mechanism on top of the gearbox (under the batterybox/airbox). Especially under braking and damaged cables. Normal warrenty applies
All the other gearbox syncho/shift issues are for Type-R cars and mostly 3th gear grinding.
Nothing for 1.8 cars...
· Premium Member
I had an issue occasionally when changing down to second, stiffness/refusal to go into gear, a bit unnerving on the aproach to roundabouts, after a gearbox oil change, (75K service), the problem seems to have lessened.
Hope this is of interest
James
· Premium Member
Discussion Starter · #10 ·
thanks buddy tryin to get a shot of another civic see if theres is the same might just be me :)
· Premium Member
I think it's one of those problems that they wont admit to. it was really bad on my 1.8 but I don't notice it on my 2.2.
· Premium Member
I think you are right, I figured after owning a Honda motorcycle that they would produce a good manual six speed car gearbox! Mine is a tad better now afer the oil change but not as good as as it could/should be, I will halve the oil change interval on my gearbox in future.
James
1 - 13 of 13 Posts
