Hi all
I have a problem with the gear,when the gear lever is in nautral it must nomalt be in the middle, but when I press it to one of the sides the gear lever stays there,and somtimes when I but it in 1gear when the car is holding still I can hear a littel low"klonk" have some experienced it.The car has run 36000 miles and is a 2008
U may also find that there is a spring that pushes the gear stick back to it central position. They have them on the focus and common to go. Jus fixed one actually. Worth seeing if there is such a part on the gear shifter in the civic:popcorn:
