Could this be contributing to the light steering at high speeds do you think?
I would like to know what shims I would need to correct this and a price for them please.
I also feel this could be a good excuse to bring the car up to you and have a FRSU done.. what would be the difference between only having the front done or both the front and rear?
What is your weekend availability like towards the end of this month?
Looking at your printout, if we were to get the same readings on our alignment rig we would advise fitting at least a couple of rear shims. We would need to reduce the passenger rear camber by around half a degree (which will effect toe), and tweak the toe on both sides.
Are you on standard suspension, or have any plans to go lower? This will obviously effect geo readings and would be best carried out before the FRS.
The first weekend we have available at the moment is the 28th
Currently on standard suspension and will be for at least the foreseeable future.
Assuming you got the same readout, would you advise to go for a FRS front and back?
I would appreciate someone putting my mind at rest regarding the steering feel at higher speeds - I'm not sure if a road test is included with thr FRS but perhaps someone could give it a quick blast when I bring it up? I am sure you guys will know straight away if it's normal.
If you could advise a price and book me in for the 28th that would be perfect.
You do have quite a lot of toe out on the rear, so that won't help the feel of the car, especially at speeds. We aim for around 2mm toe in, to keep the rear stable at speeds so i'm pretty certain you'd feel a big improvement if you went for a full front and rear setup.
Could you give me a call sometime today, i'll take some details off you and a small booking deposit and get you booked in.
A cost based on using a maximum of 4 shims is £224.00 inc VAT and all labour. Job time is between 2 and 3 hours.
Hey guys @ABP.
You guys doing any suspension work on FK8's. I know you guys are famed for FN2's, but I've seen nothing to show you work on the newer CTRs.
ABP CIVIC TYPE R XMAS 2018 SPECIAL OFFERS
• These offers are exclusively for December 2018 ONLY.
• Some items have very limited availability – once they are gone they’re GONE!
• All prices include VAT
• Fitting is available on all items – please phone for competitive fitting prices
I've just had one of these supplied and fitted though Abp, all I can say is I'm loving roundabouts even more now! It is a lot more planted and the rear hardly moves now, the ride comfort is the same it's just the turn in that has improved a lot.
I would recommend getting the rear bar when...
FN/FK chassis (8th gen Civic) suspension & alignment upgrades
ALIGNMENT
On a standard 8th Gen Civic the only thing that is actually adjustable is the front wheel alignment (toe). We can also make the front camber adjustable with the use of Eibach adjustable camber bolts - this is essential to...
