Glaze over wax?
2040 Views 33 Replies 8 Participants Last post by  IrishTom
Hi all, I glazed my car a few weeks ago and have since applied 2 coats of HD Wax. Is it possible to glaze directly over the wax or will I have to strip the car right back?
Thanks folks
Matt
1 - 20 of 34 Posts
No....Glazing is a pre wax or sealer stage
TBH..If you recently appled two coats of wax.....You wont need any more until it stops beading.
Hi Robbo, thanks for your reply. When the car stops beading I should re-glaze before waxing?
I would give it a claying..In the Spring..
Then polish if there are any swirls..Glaze..then rewax
I did this procedure a few weeks ago and waiting for spring before next clay session. I trying to determine the best 'top up' methods!
Quick detailer or even auto glyms aqua wax will top up the wax
Personally having used HD wax, you can layer it. When I had 4 layers on I used AG Rapid Detailer after each wash, it is very good. If you were nearer you could have mine as I won't be using it again as I have moved on from AG products.
Meg's quick detailer? Really??
Megs would work, I prefer to use the same brands ie Megs wax then Megs detailer. AG wax so AG detailer ;)
I only mentioned aqua wax as it means you wash the car and wax it in one process instead if having to wash it dry it and wax it.
I do agree that using the same make of wax and quick detailer is probably a good idea
Brilliant info guys thanks very much!
Once again I am in your debt!
Unless you are parked by trees with tree sap as a real danger, you should not need to clay your car for about a year. Personal opinion of course which is open to debate.
Clay mine every 6 months, not to get rid of tree sap though. Lots of other types of contamination, tar, iron, fall out etc.
+1, My car suffers from tree sap on my drive in the summer but a nice warm wash easily removes it, i guess thats where plenty of wax protection helps.:D
Agreed ;)
Whatever you are into mate. Personally I love claying and only do it every 12 months because a clay job means a whole days hard labour. I used tree sap as an example and agree there are other contaminants. I'm not a high mileage driver so probabl why my car doesn't need regular claying. But you can over do it. Its a personal opinion of course and open to challenge/debate.
Mileage does not have that much to do with it TBH. Fallout falls on parked cars more than moving ones ;)
Claying the car takes me around 30 minutes max
Even with tree sap, it should come off easily if youve a good layer of protection there in the first place
+1
But be carefull and gentle if you dont want to micromarring the paint.
1 - 20 of 34 Posts
