1 - 2 of 2 Posts
Hi, I am in need of help I've posted 2-3 times and had no response :confused:.
I have a 2006 2.2cdti civic about 8 weeks ago I had a grinding from the brakes/pedal but weirdly this only happens when I use my brakes 2-3 times then for the rest of any journey they are fine until the car is parked for more than an hour and same process begins.
Checked pads and discs and they are fine.
The vga & abs lights are on garage I use diagnosed front left abs sensor not picking anything up so replaced sensor TWICE still the same readings are fine from other 3 wheels but no reading at all not even speed from left front.
They have now said the only thing they can think of is maybe it's the wheel hub ( they tested sensor off the car worked every time.
Anyone got any other ideas
Been suggested to take it to a honda garage, can anyone recommend one Cardiff,Newport way that won't cost the earth.???
I would put a hub on it. Obviously if it's not picking anything up from it and the sensor is fine as its new it points to the hub. If not it's always something else ruled out. The mate has the same symptoms on his 07 diesel Passat and it needed a hub.
1 - 2 of 2 Posts
