1 - 10 of 10 Posts
Do you supply H&R spacers?
Looking for part number 1065640
Its listed for an Accord Type-R, but is also 5*114.3/64mm centre hub which matches my 2007 1.4 Civic I believe.
Its a 5mm, hubcentric spacer.
Thanks,
Thanks,
I've just sent off an email to our supplier and importer for H&R, so i should get a response soon.
The only thing i would say, is that i'm not sure a 5mm hubcentric spacer is possible. Eibach go as small as 10mm, because you have to allow for the size of the hub flange which sits inside the spacer. I think the flange is around 7mm (after measuring one of our spacer kits off the shelf) So a 5mm hubcentric kit isn't possible.
Hope this makes sense.
Rich
Thanks Rich, I think you are right.
Looking around, lots of places show a picture of the item as being hubcentric, but there is also evidence to say it isnt hubcentric.
How much do you charge for a 15mm hubcentric set (System 4, so i dont have to mess around) ? And how much is shipping to Ireland.
Thanks,
Thanks,
I keep the 15mm spacers in stock, at £110.00 per axle, inc VAT. I think that maybe a generic picture people use, as according to their specs, 10mm is the smallest they do but nothing in that size with the correct centre bore.
Let me know if i can supply you any of the Eibach 15mm, bolt on types. I can get them shipped to you for just £10 next day.
Rich
I've sent an email to you this morning, let me know if you have replied as my work emails filter can be a bit strict and block some replies.
Which email address did you send it too? I have alot of junk email each day but i haven't seen anything else this morning.
Rich
Sent it again, but guessing you havent received it. Will send a PM.
1 - 10 of 10 Posts
