Has anyone got their wheel alignment done after changing h&r lowering springs? Did you have to use camber bolts to reach the factory settings? Thanks.
Having Eibach's fitted as I type this and then re alignment so will see what they say.
Anyone fitted spacers with 17" wheel on a mk9????
I have had Eibach spacers fitted now, but thank you. Looks excellent with the Eibach springs. The rear camber is very slightly off factory but not to make any real difference. Not sure how low H & R go but if they are lower than the Eibach;s then you will be further out. Are there any camber bolts out there for the Mk 9????
