Hi All,
As usual coming for some of your expert advice...
Recently had to replace both of my H7 Bulbs... Used standard Halford lights and although was quite a faff because of the very confined space to actually remove the old ones and put the new ones in I thought I had done it correctly...
However and this is the bit where I probably start to sound very poor in terms of technical description.. I can't help but feel that the beam of light is pointing more towards the sky than the ground.. so much so that I followed someone home the other day and they asked why I had my full beam powerful lights running...
From what I can make out the lights are seated correctly although the clasp gripping them wasn't the easiest to pop back on how severe does misalignment need to be to actually affect the light direction?
I will take another look again in the daylight but I thought id ask to see what peoples view are.
Thank you in advance.
C
C
