DumpNAVI by bysin
about:
<B>
DumpNAVI is a program that extracts files from Honda/Acura navigation DVD-ROMs. The program ONLY works on Honda/Acura navigation systems running the Hitachi SH-4 Windows CE system. For discussion, please visit AcuraZine
</B>
Downloads:
<B>
</B>
Documentation/Howto:
<B>
DumpNAVI by bysin-----------------This program is used to list, extract, and modify filescontained in an XIP BIN file located on Acura/Hondanavigation DVD. This system has been tested on theTSX. Use at your own risk.Some of the things I have been able to modify are: - Changed the background picture to my own personal image. - Removed the "nag screen" at the beginning screen. - Change some of the words that pop up.Here are some step-by-step instructions on how to modifyfiles in your navigation system. It requires a DVD-ROMdrive and a CD or DVD burner.1. At the main screen of the navigation system, hold down the Map/Guide, Menu, and Cancel buttons for 5 seconds.2. Hit the "Version" button on the touch screen.3. Hold down the Menu button for 5 seconds.4. Write down the filename next to the words "Loading Filename" (ex. BNHN404A.BIN).5. Open your trunk and find the DVD player attached to the navigation system.6. Push down the front plate and eject the Navigation DVD-ROM.7. Place the DVD in your computer and copy all 9 BIN files onto your hard drive (should be around 104 MB), this includes: BN2HH12C.BIN BN2HH110.BIN BN2HH120.BIN BN2HHMLD.BIN BN2HN12B.BIN BN2HN18B.BIN BN2HN380.BIN BNHH401A.BIN BNHN404A.BIN8. Use the dumpnavi tool to extract the files on the BIN file that was on your car, ex: dumpnavi BNHN404A.BIN extract9. The files will extract to the directory associated with the name of the file.10. After modifying the files, use the dumpnavi tool to update them to the BIN, ex: dumpnavi BNHN404A.BIN update Back.bmp dumpnavi BNHN404A.BIN update navi.exe navi-nonag.exe dumpnavi BNHN404A.BIN update Diag.exe11. Copy the modified BIN file, including all other BIN files (9 in total) to a blank CD or DVD.12. Insert the origional navigation DVD back into the DVD-ROM in your car.13. Start the car normally, and at the main navigation screen hold Map/Guide, Menu, and Cancel for 5 seconds once again.14. Hit the "Version" button on the touch screen once again.15. Take the origional navigation DVD out of the car, and replace it with the CD/DVD you just created.16. Hit the "Load Disc" button on the Version screen.17. It should take about 20 seconds for your car to load the new BIN and reboot. Once that happens, take out your burned CD/DVD and put back the origional navigation DVD.18. If anything goes wrong, remove the ground to the battery for 30 seconds with the origional DVD in the car. The old OS will load back on the system.
</B>
Background Images:
<B>
Here are some images you can use to replace Back.bmp. Right click on an image and hit "Save Target As...", then issue the following command to DumpNAVI (when your at step 10 in the readme) to import the new background: dumpnavi WHATEVER.BIN update Back.bmp BackX.bmp ... For example: dumpnavi BNHN404A.BIN update Back.bmp Back1.bmp
</B>
I like this one ! - MUST have ! ...
