Hey,
(posting on behalf of someone else) As title suggests type S 2011 when the handbrake up the dash light doesn't come on any tips to get it back on!
Whole reason it was noticed was because the tyre pressure light came on, after making sure the tyre pressure was OK and turn the light back off he can't access the screen past the 30/50 alert as the car doesn't register it's stopped and not driving and won't allow into this screen till the car is stationary with the handbreak on.. Which it is but for some reason the lights not on its not registering as on?
Any help? Tips?
Do this test to see if the bulb works, But I would say it is the Handbrake position Sensor
Before doing the self-diagnostic function, check the No. 10 (7.5 A) fuse in the under-dash fuse/relay box and No. 16 (15 A) fuse in the under-hood fuse/relay box.
1. Push and hold the SEL/RESET switch button.
2. Turn the headlights ON.
3. Turn the ignition switch ON (II).
4. Within 5 sec., turn the headlights OFF, then ON and OFF again.
5. Within 5 sec., release the SEL/RESET switch button, and then push and release the button three times repeatedly.
NOTE:
•While in the self-diagnostic mode, the dash lights brightness controller operates normally.
•While in the self-diagnostic mode, the SEL/RESET button is used to start the Beeper Drive Circuit Test and the Gauge Drive Circuit Check.
•If the vehicle speed exceeds 2 km/h (1.2 mph) or the ignition switch is turned OFF, the self-diagnostic mode ends.
