1 - 19 of 19 Posts
hi all just bought hds/him from fley bay and could do with some help
to connect it to my 2008 civic i have installed all the software that came with it iam running windows vista with usb to serial adapter on com 1
but no matter what i do i can not get it to connect to the car
any help on setting it up thanks
Bye bye Honda...
Is the software communicating with the HIM OK?
Have you turned the ignition on?
make sure you have downloaded and installed the driver software for the usb to serial adapter. i had to get mine from the net after it installed it worked
drvers are working for the usb adapter
just a thought will it run on vista or does it have to be windows xp?
ok
any one got a step by step guide on how to connect it to the car
is this right
1 plug the the hds in to the lap top
2 press and hold the enter button to program the hds
3 plug the diagnostic cable in to the car
4turn on the ignition on
5 read the codes
Hi
What type of the usb to serial converter You use?
There are 2 types generally
PL2303 cheapest but sometimes not good
also I used Unitek with Y-105 driver with positive
FT232 -2-nd generation the best for OBDII transmision.
good luck
did you get this sorted ? I've got the same problem , just yellow and green light flash on the him but can't connect to the vehicle
no not at the mo
i have tried 2 usb to serial adapters one a PL2303_Prolific
the other a FTDI CHIPSET
when i go to connect it to the car it says
HDS has been unable to confirm connection to the vehicle
but it will update the unit if i press the enter button on the hds unit
it is on com port 1 running windows xp
also if i use the obe scan tool that came with the hds software this works
Mine done the same but wasn't able to update the unit as it wasn't connecting to my laptop.
If it's updating then it must be a connection from the him to the car
I'm guessing you can connect a normal obd2 scan tool to the car ok ?
Discussion Starter #12
when you install the hds software it also installs a obd2 scan tool at the same time
this scantool will connect but the hds software will not
mine are also longer.
Im guessing youv tried deleting and re-installing the software on your pc
And also have selected the device your using as HIM
1 - 19 of 19 Posts
