1 - 2 of 2 Posts
right habd drive honda civic mk 8 type s fn 57 plate .67000 on clock . The other day the heater fan started working when it wants too i swapped out the control pannel on dash still have the same problem ,when it does work it allows me to use all fan speeds ,does this mean the resister is still working fine,everywhere seems hard to get too
the resistor will be fine
sounds like a bad spot on motor if it stops on it wont re start
I changed mine a few years back on my 2.2 8g not hard job just need patience as the room to work is right on the edge and you need your body to be flexable
just try not to do it when its 26 degrees like I did you loose a fair bit of body fluid
1 - 2 of 2 Posts
