Hi all please help, my heater is cool and my engine temp gauge is up and down, tried flushing the radiator but still having the same problem, any ideas? Thanks in advance
You do not bleed from the bottom of the radiator, that is a drain plug.
With your symptoms, it sounds like you have an air lock.
On the derv there is a bleed screw on the block. I suggest you do some research on the correct bleed procedure for your engine.
Ah, this pretty much confirms that you need to have another bash at a flush/bleed. I've PM'd you some info.
Let us know how you get on.
