I was just wondering if anyone has any idea or experience with the problem i am having.
My car is a 2007 1.8 Type S GT
When i have the heating on, i can set it to "HI" and its red hot, but if i go down 1 turn to "28" (degrees C) It turns cold. There seems to be no in between.
When i first got the car it worked fine.
Does anyone have any ideas?
Regards
Liam
Perhaps a faulty sensor. If you set it to high it disregards the sensor reading as far as I remember from the manual (similar story if you set it to low). Also check that the cabin sensor is not covered with something.
Cockup Specialist
Is 28c not a set temp and hi as hot as poss ???
If you are hotter than 28c the car will add cold air to keep the same temp.
Is your external temperature sensor reading normally? I had exactly the same symptoms when my sensor was broken and it was reading 55c outside!
Reactions: liamhenning
I think that could be it mate.
My temp sensor is reading anywhere between 46 and 55. I am just waiting to get to the dealership to have it fixed under warranty.
Ill post when i have had it fixed to tell you if it works.
Thanks.
