1 - 9 of 9 Posts
Hi all,
Picked up an 08 2.2 type s a couple of weeks ago. Great car but needs a bit of tlc.
So far, thanks to this place, I've adjusted the biting point of the clutch, replaced the horrendously noisy pattern air filter and swapped the omron air con relay for a mitsuba. It didn't fix it as the condenser had a hole in but it was bust.
Bbb
Hi there and welcome to the place :D
Thanks, forgot to say I've cleaned the egr valve using the guide on here.
Thanks all, not sure if the manifold has been swapped. Was reading the thread the other day so keen to check if it has the cast one on. Fancy doing coolant and mtf change as well.
1 - 9 of 9 Posts
