1 - 9 of 9 Posts
Hello all I've finally got one! I have been wanting a civic for a while now. Couldnt stretch to a newer mark but Ive always liked the look of a mk8 so I got one for a good cheap price. It's a daily work runner and for little runs around. Was using a lwb van before and eating fuel! Since I got it I've had a few little faults I've sorted and a couple of big ones. The clutch gave out last week. Unsure if it's the original as its not got much history but at 14800 I was expecting to have to change it at some point. The only other big problem I have is a have a parasitic drain somewhere. I'm suspecting the 12v aux sockets as they not working yet the fuse isn't blown! I've found some good stuff on here to help so I thought I'd join and say hello and cheers for the helpful stuff here!
Andy
Hi Andy, Welcome and well done acquiring your own 8th gen.
Is it a 2.2 derv?
I presume you meant that the clutch failed at 148k miles?
Hi its a 1.8 ex 5door and yep it's got just over 148k on the clock! Clutch systems is being replaced at this moment! The rest of it has run fine since I bought it apart from this dam electrical fault draining the battery The bad weather's not helping either as I don't have a garage but hoping to tackle the problem soon.
Ah the dreaded electrical fault, as you have an EX then I'd wager it has HFT (hands free telephone) and the module has gone bad - they are notorious for it. The module is located on the panel under the steering wheel and you can easily unplug it, then see if your battery drain issue improves ;)
That was disconnected within a day of picking the car up! It would constantly connect and disconnect so I unplugged it! The problems started when I noticed the 12v socket wasnt working and the fuse was blown. I replaced it but the socket still didn't work yet it didn't blow the fuse! Going to pull the fuse out and trace the wiring to see if I've got a short somewhere.
I have just brought a 1.8ivtec ex. 55plate my first honda. Immaculate with loads of gadgets. Loving it to drive having come from a rather agricultural Suzuki Jimny.
1 - 9 of 9 Posts
