new to the forum...just bought a 2009 es 2.2 diesel hatch...
the ac isn't working, and i had a specialist look at it...he said it's the compressor...
so, i'm looking for a used one...had 4 quotes that seem reasonable...how can i be sure that they'll fit my car...?
also, i'm not sure that my car is a 09, or a late registered earlier model...how can i find out...?
thanks
For the manufacture date, I think you may be able to get this either from the door panel serial number, or VIN Number - Can't remember the particularities from the top of my head, but you should be able to decypher the door sticker; VIN Info can be found on the internet.
As for the compressor, Did they attempt / complete a regas? If so, And it is retaining pressure, You could be worth shimming the compressor clutch - Might save you buying a new compressor.
yes, the ac was full...so it's retaining its gas...
i've read about shimming...but i'm not a mechanic...absolutely no tools...lol
also, i have the vin number...where can i look it up...?
i-Vtec
Id try the relay first, it may be just that that is knackered. For £4 id try that first before swapping a compressor.
https://www.ebay.co.uk/itm/Fuse-G8HL-H71-12VDC-A-C-Compressor-Relay-FOR-Acura-TL-Honda-Accord-Civic-Omron/113048985465?epid=15020264348&hash=item1a523e9f79:g:TVoAAOSw4Q5bG16S&_sacat=0&_nkw=civic+ac+relay&_from=R40&rt=nc&_trksid=m570.l1313
Btw do you mean is it a Facelift Civic? If its a face lift it will have the 2 nostril front grill.
