Hello all,
2007 1.8 type s owner here.
Been lurking for a bit and wanted to say thanks for all the useful guides I have come across.
Thanks to guides in this forum I have done the following:
Fixed cig-lighter in place
Replaced air-con relay
Installed connects2 bluetooth interface and mic
Clear rear indicators
Fixed the light in the boot where the wire had dropped behind the trim
Installed updated dash surround with matte finish and buffed the plastic on the speedo
Fixed the crazy wipers (lifesaver, this was driving me mad)
so it's fair to say this forum has been a valuable source of information for me, so thanks again to everyone sharing guides.
Next I'm going to try and fit a double din head unit. Got a sony ax3005db on the way, and just received the OEM fascia in the post.
Didn't realise the original fascia is different to the one you would get with the connects2 kit. Is there any way to fix the head unit to the OEM fascia without buying the brackets from Cox that are £50 a piece?
Here's the car back in the summer after a wash, clay, polish and wax
Hi bfc , just to let you know when you fit your new head unit the aerial is powered so you need to connect the cable that comes with the aerial lead into the blue spare lead in the wiring harness, this will allow you to receive all your stations , hope this helps, good luck
Great thanks for the tip Maurice
