I was installing new LED's for my number plate lights and all of a sudden my rear lights and number plate lights went out. They don't turn on at all when I have my headlights on. Basically only my headlights are on. Help
Sounds like you've blown a fuse/s. were the lights switched on when installing the led's ? Don't know if number plate lights are fused sepaertely to sidelights or not. have a look in hand book for fuse locations.
Yeah they were, what was I thinking.. I was in a rush to change them. Yeah they are cause both of them went out same time. Its not that hard changing fuses is it?
No
Fuse puller tool in the under bonnet fusebox. Then you just need to be a bit of a contortionist to see the under dash fuses.
if you can change a bulb I am sure you can handle a fuse!
