1 - 19 of 19 Posts
Fitted Dension gateway 100 GW15HB1 to my Type R. Problem is I dont seem to be able to select disc 6 on the cd changer. The display just displays "CDC" and will not let me change it on the head unit. The ipod lights up with the dension logo and charges but there is no sound and I cannot control the ipod.
Any info will be appreciated.
Discussion Starter #2
Dension CDC select fault
I have fitted a Dension 100 Gateway. The problem I have is I need to select cd6 to access the dension, but the display is locked on "CDC" and will not change on the buttons.
The rest of the radio controls work perfectly its just the cd selection in cd changer mode.
Any ideas.
When I connect the ipod it starts to charge and displays the Dension logo but I cannot select anything, because I think I need to be on cd6.
When i plug my i-pod in it runs on Cd5. I think it should work on both CD5 & 6. Does yours play through the radio?
The problem I have is I can't select any cd. The display seems locked to CDC and I can't select anything. I can select fm and it will play cd's it just will not move off CDC when the Dension is connected
Battery
If I disconnect my battery will I lose my radio code?
Need to reset the radio back to factory settings.
Type R 2007
Dension CDC lock up
Well disconnected the battery to hopefully reset radio but no joy.
When the Dension is connected the CDC is locked and will not let me select cd6.
I have disconnected the dension and i cannot select CDC when I reconnect the Dension I can select CDC so the radio is detecting the Dension but the radio still locks up.
HELP !!!!!!!!!!!!!!!!!1
Type R 2007
dension gateway 100
This is a bit worrying for me, I have bought one of these and the car goes to a local ICE specialiast in the morning to have this and a parrot hands free kit fitted.:confused:
I hope I don't get the same problems.
The firmware is the latest on the ipod not sure about the dension.
I am waiting for a reply from Dension tech support.
Tonysee keep me informed how you get on tomorrow
Discussion Starter #14
A step forward. I can now get the ipod to play for 2 sec but then the ipod displays "ok to disconnect" and stops playing
I've had this exact same problem with the first dension gateway 100 i received. I had to get mine replaced with a new one that had a newer firmware which worked.
You won't be able to upgrade the firmware as you can't play the files cause the default mode is ipod gateway interface which disables the ipod click wheel.
just take it back to who you bought it off and ask for a replacement with the newer firmware.
Seik
as far as i know only the satnav radio systems have pin numbers that need entering when the battery is disconnected.
Ezermester
Mine doesn't.
I have a similar problem. I installed a GW 300, on the sat-nav unit (soldered the three wires together, w/o the Y-cable). I usually works fine, but sometimes it locks up on start, as described in previous posts. Restarting the car fixes the problem. I presume it is the rearview camera kicking in, if I select reverse too soon, and also at night when auto lights come on. So, since the original 3 wires are for the lcd, there must be a problem the signals interfering with eachother.
Anybody experienced such a behavior?
Andrej
I have a Dension Ice Link Plus(forerunner of the GWay 100) and selecting CD6 takes the Dension in to the iPod set up menu and is used to change settings only. If yours is the same then the iPod should show settings available and can be changed via the radio controls.
1 - 19 of 19 Posts
