Hi, supercharger fitted and running but cylinder 4 injector not running! Any ideas?
When you disconnect the wiring plug there is no change.
Dave.
Earth Dreams :)
Anything coming from the harness itself, checked to see if there are any amps with a multimeter.?
Not yet but will do, thanks.
Any idea how many amps I’m looking for.
Dave.
Swap injectors over and retry to rule out bad wiring and/or injectors
Will do as a last resort but have to remove the charger again to get them out. Will swap harness first.
Earth Dreams :)
Should see a signal of at least an ohm as I recall, simplest way is to do a test light test.. hook up the harness to a lil test bulb crank the engine.. if she flashes, there is a signal there.. then see what kind of ohms u get.
