For weeks my radiator is blasting out cold air, on occasion it will blast out warmish air. Even after driving for an hour the car still feeds cold air with the temperature on high.
Temperature gauge in car is working correctly with the gauge moving up half way.
I have also checked the coolant level which seems to be okay
Does anyone have any suggestions on what this could be?
Internet is no help unfortunately
Honda Civic type R Fn2 2008
CTR
Bleed the system, check for leaks, water level. Maybe thermostat issue.
Could be motor in car recerculation one or drivers side not working. So it can't be set to warm even if screen shows.
Friend had similar case where drivers motor was faulty and only cold air was getting even if temperature wad set to Hi.
