Hi all, am in need of some help here if poss.
I have a new xcarlink unit I needed to change the mic unit on.
I did assembled dash and re fitted.
All was working well when tested until I went to put car back on drive.
Engine management light warning....Air bag warning and VSA warning!!!
Am thinking I've disturbed something but at the moment car won't start.
Please can someone help?
Maybe disconnect battery for a few minutes to reset the ecu, just a suggestion mind but that's what I would try first
Sent from my SM-G900F using Tapatalk
Thanks all.
Some in depth forum research pointed me in the direction of the INERTIA FUEL CUT OFF SWITCH.
Problem now solved :eek::eek::eek:
This is something anyone delving behind dash should be aware of BTW.
Thanks again all
Ahhh iv read about that, it's a safety thing incase you flip car or something. Glad you found it I forgot about it till you just mentioned it then
