Yes but you also have the gap at the top of the rear arch. I just stuck mine and clamped it overnight. Mind I have seen it mentioned about longer clips or sticking ones to each other. The splitter should fit as I done this to a 1.8 and the 2.2 although if I remember right I may have taken a shave off the black plastic scoop that the splitter may hit against on the 2.2. I fitted these with the bumper still on the car. Hope this helps.just leave the gaps buddy you can only see it with the back door open
You don't have to modify the rear arches.There shouldnt be a problem fitting these at all mate! Try somewhere else or do it yourself its pretty easy with a bit of patience :
Speaking of rear arches though and dont mean the thread jack! I have got my rear type R arches today and they look like they might fit with the standard skirts on... is this possible? Would save me cutting and plastic welding!
hi buddy i read on here the rear type r arches fit onto the standard skirts its the front that need moddedThere shouldnt be a problem fitting these at all mate! Try somewhere else or do it yourself its pretty easy with a bit of patience :
Did you ever get your bumper done by fibreworx mate?Hi all, I've got I problem with fitting the front bumper with the type r splitter. The front cross member don't let the bumper fit, its touching the splitter.
Anyone add this problem?
:facepalm:
