hey guys,
Hope you can help.
Last year my air-con gradually started to deteriorate, i then found a leak in one of the air con pipes under the bonnet, i had this leak repaired and the system recharged, this improved it slightly but it was still nowhere near as cold as it used to be.
With the weather warming up i could really do with my air con back to normal, i looked through the "wiki" and followed the instructions for a diagnostic test, no error codes have popped up however my display has changed slightly?!?
Before the test the temperature settings would read from "lo" through 16, 17 18 etc degrees and then to "hi", now there is no "hi' Setting and i can now go below "lo" down to 15 degrees?!?
Can anyone shed any light on either of these problems, i dont really want to pay Honda's price for a diagnostic!
Cheers [smilie=ebil-thumbu:
...............Daedalus
Never heard of that problem before, the temperature range shifting. I think that will defo be a trip to the dealer for that.
As for the AC not blowing cold enough, I'd say have it leak checked again.
