1 - 11 of 11 Posts
I know the drop links have a green liquid/grease in the ends - so it may be one of them that's blown.
have you driven the car since?
try using the aircon - that will rule that out.
try going over speed bumps - that will rule out the drop link
First of all, thank you for your feedback.
The problem is solved, it was hardly a tight clamp circuit cooling system LPG.
The LPG system uses the same liquid to cool the engine and I spotted the first few drops and therefore not noted in the level of the liquid.
I'll post pictures of the liquid on the floor for other members to identify if it happens.
Best Regards
1 - 11 of 11 Posts
