1 - 14 of 14 Posts
hello
Can anyone give me a step by step guide of replaceing the rear speakers and how i can get to them ?
Welcome to the site , this hasnt been done so far i think. The speakers are shocking ive changed the fronts
Thanks ill try find it,
parts are ordered so may just give it a go if can't find it by the time it arrives.
If you manage it a how 2 with pic plz
That picture that Pottsy showed is overdoing it a lot. Its fairly simple actually.
The red arm support where also the cup holder is in is removable.
If you bend gently in the front part between the red cloth and the black plastic you can get it up. After that there is 4 (or 5 screws) that holds the panel that the speaker is behind.
Hope that helps.
What size are the speakers ? Anybody
Hope that helps.
I have just tried to remove this panel , but it seems totally fixed. I dont want to force anything. Could you add some more explanation as to how to remove. A picture is attached if this helps. Thanks.
I'll do you one better, I'll show you.
After you have gotten the arm rest up you just screw out the 6 screws and gently pull it out in the bottom part. Preferably you pull where the cup holder was. It is the red canvas panel you pull out not the part under the armrest and then you can get too the speaker.
Hope that clarifies.
Brilliant - Thanks very much.
Iam changing mine now
1 - 14 of 14 Posts
