Is the plastic shield where the wipers are connected to? Do I remove the wipers? And is there any wiring for that?Extremely simple to do. Remove plastic cover. Disconnect coil pack, undo bolt of coil pack, pull coil pack out, use a long socket and adapter for spark plug, undo it, magnetic bit to get it out. Reverse. Sorted.
Sent from my CLT-L09 using Tapatalk
I had a look and the coil pack is on the rear of the engine so not under the plastic cover. I believe this engine shares similarities with the Honda jazz of this era. And the gap is very small, no way of getting a wrench into the socket without removing the plastic shield holding the wipers.No the plastic cover over the engine, two plastic screws, twist them and lift the cover off. No need to remove wipers or anything like that.
YouTube is only showing the 1.8... it's like no one bought the damn 1.4 lol?Maybe 1.4 is different to my 1.8. Only took me matter of minutes. YouTube will be your friend
