Hello,
Ive recently installed a double-din stereo but I haven't a clue where to wire the break cable so I can watch DVDs.
I've obviously had all the centre console out and touched it on the break cable but nothing happens.
There is a bunch of wires leading off it but the instruction manual kinda expects you to be a technician.
Anyone have any ideas?:(
If you want it to work all the time wire it to one I the bolts at the back behind the handbrake. There is a control box of some description and that will work.
Pop a DVD in and let it play then touch the bolts till you find a suitable ground.
If you want it to work only with handbrake on I think you will need to wire it to the switch that tells the handbrake light to come on/off
#MrGrumpy
Assuming it's requiring a ground to enable playback, you can connect it to any bolt that is grounded (so anywhere on the chassis, or connected to the chassis) and it will work.
This,
Remove a bolt stop off about 3cm of insulation wrap the wire round the bolt the screw it back in and tighten.
