· Registered
Hi i need some help with my hid's the starter if thats what the little sliver box is called was humming then the light went so i ordered a like for like replacement box and it still did not work so i the checked the bulb and that is broken on the little but that runs along the bottom all i know its a h1 bulb on an ep3 its 55w pro max but i don't know what bulb i need because there are 3 options 5000k 6000k or 8000k please help as it dose not say on the bulb
many thanks
neil s
· Premium Member
They could be anything, 5k, 6k, 8k, 10k...
You need to buy a pair of new bulbs which are 55w rated, it doesn't matter about the "K" rating, any will be compatible with your ballasts.
If you would like to buy some from me let me know.
· Registered
mr jp, I need some info mate, I got you kit, then got a bulb off.you as
one died. now it seems my headlights are different coloyrs?? one is perfect white the other is blue?
is it possible you sent me a slightly different bulb? its been quite a while since I got it off you but I only just noticed since the nights are darker.
can you sent me a price for two replacement bulbs? cheers mate
· Registered
