Alright lads!
Just bought the missus/myself 馃槀 a type-r gt fn2.
Loving the vtec! It's like being a kid all over again ha.
I have came across a couple of issues already if I could get some advice though please.
First one is abs vsa check system has came up & won't go off, I'm thinking this may be something to do with the abs sensors either wiring or dirty? (I've got a Bluetooth obd for the torque app on order)
Also, I disconnected the battery for an hour to see if it would forget the fault (which didn't work) however I can't get the audio display up on the navigation screen now, the button is beeping when pressed & the audio display occasionally pops up but goes straight off again. Menu, info & climate displays still appear on the navigation screen as normal, would really appreciate some help on this it's driving my ocd crazy 馃槀馃槀
Welcome to :civinfo:
It does sound like an abs fault, a good reader will tell you which wheel is bad.
Odd that the radio has just popping, did it before you disconnected the battery?
Hi thank you for the reply.
Yes the audio display came up as normal on the navigation screen previous to disconnecting the battery
