1 - 10 of 10 Posts
Discussion Starter #2
Replace fuel pump still no joy looking at the pressure relief valve no fuel coming out the breaded pipe could this be a problem as still have no fuel to the injectors will start with a spray of easy start
Check cut off switch the key was not in the car when it starts I get lots of think black smoke out of it
It was playing up before had to jump start it would that do it. Why would it smoke so bad if the key was at fault
if the key was clapped it would not start at all since the ignition is disabled.
so not the issue here since you can get it going, just badly.
not a diesel driver so can't help any further
1 - 10 of 10 Posts
