Our rear motor mount for the 6 speed manual is officially available now!
Link to buy: 2016 + Honda Civic Rear Motor Mount (6MT) - Boomba Racing, Inc.
Install guide: http://www.boombaracing.com/content/CIVIC X - MOTOR MOUNT MANUAL.pdf
Features:
-Molded in polyurethane bushing
-Eliminates wheel hop
-Increases traction
-Eliminates “bang shift”
-Premium aircraft grade billet aluminum
-Reduces engine flex
-80 durometer bushing
These direct bolt-on mounts combine to replace the rear engine torque damper, significantly improving the vehicle’s traction and shifting response by reducing excessive engine flex. Wheel-hop during hard launches is also completely eliminated thanks to these mounts.
Boomba Racing mounts are machined from high quality aircraft grade billet aluminum for strength, durability and looks. Inside each mount you’ll also find solid poured-in polyurethane bushings with the rigidity carefully chosen to optimize vehicle stability while also minimizing excessive vibration transfer from the motor to the body.
Installation is simple, does not require engine support and utilizes all OEM hardware.
Available in your choice of color: Black, Blue, Red, or Pure Aluminum
DSC_4623 copy by Boomba Racing, on Flickr
Discussion Starter #2
Any questions?
These fit the Type-R also!
