1 - 1 of 1 Posts
Sponsor
HKS Direct Multi Recorder (Latest Model) DMR-200D 49010-AK003
Advanced drive recorder HKS DMR is released to handle driving for various purposes!
A record of driving is one way of enjoying car life. "DMR" can record driving images from various viewpoints with 2 cameras equipped.
Specifications
Hardware
2 cameras are originally equipped:
Main Camera: 70mmx26mm (2Mpixel)
2nd Camera: 40mmx18mm (350Kpixel)
Variable rate 20~1.25fps enables 1GB/6 hours recording at longest.
New DMR monitor size is 1280 x 480 which enables efficient data compression.
* An extremely long period of recording time is available, and the length of time used for monitoring and recording is greatly expanded.
* Up to 64GBmicroSDXC card are supported.
Radio interference to digital broadcast, AM radio, FM radio, etc. is reduced.
* Radio interference may occur by condition.
The size of the main camera is 70mmx26mm, and second camera is 40mm×18mm, which are the smallest size available for drive recorder (as of 2014.10).
GPS & 3D sensors are equipped
Variable cutoff feature supporting continuous operation is equipped.
Variable cutoff feature allows continuous operation of the unit while the car is not running but switch off at the set voltage to protect the battery.
External image output terminal is equipped.
Viewer Software (Downloadable from HKS' website)
Monitor size is 1280mm x 800mm
GPS signal enables location display on Google Map TM.
Seamless image obtained by HKS' unique recording method can be checked.
The complete video including the viewer data can be exported as a file.
£299.00 Including VAT & UK Mainland Postage
1 - 1 of 1 Posts
