Sponsor
HKS SUPER HYBRID OIL FILTERS £16.78+ VAT UK DELIVERED :cool:
Sumo are pleased to offer for the FN2 the HKS Super Hybrid Oil Filters at £16.78+ vat - FREE UK DELIVERY !!
A new concept oil filter which improves oil pressure drop and flow properties by approximately 30% compared to current sports oil filters. Large diameter "Super Intake Hole" and newly developed low resistance hybrid filter allows for low pressure loss. Engine response is improved by reducing the load on the engine.
Most sports oil filters are assumed to use high viscosity oil and therefore filter paper strength is prioritized whilst sacrificing absolute pressure loss properties. HKS Hybrid Sports Oil Filter has readdressed filter strength and overall structure to provide the oil flow that the engine requires and pursue HKS' ideals in what is required from a sports oil filter.
Under normal usage, it is recommended that the filter is changed every 10,000km or 6months. For Sports driving, the recommended distance is approximately 1/3 - 1/2 of the previously mentioned figure (as the engine revolutions are several times that of normal driving). However, to maintain optimum low pressure loss properties, it is recommended to change the filter every 3000km when an oil change is performed
thanks for the help caroline
Well it does seem to fit as the picture supplied shows one fitted to carolines car.
It appears you may have the wrong fitment, if it was wrong though wouldn't it have just been easier to ring them up & explain rather than waiting for eBay replies...they are a major tuning company with a good reputation so I'm sure they would sort it out for you & with the amount of e-mails & computer communications they would be going through regularly it might take a while.
If I had brought it then I'd have just made the 2 minute call & spoke to someone to resolve it.
Try it & see if you have some more luck.
Sponsor
They do fit..as Davek spotted , the pic above shows it fitted on my FN2!! I have replied to you in the thread that you posted..look forward to hearing from you:)
these dont fit the fn2 !! i bought on off you from ebay and it didnot fit! and when i sent you a message you didnt even bother to answer me back !! :banghead:
