Even though the plug is the same, our civics pin configuration is different. The bus pins are what the the HU what device is attached... This is the USA pin out... I seem to recall someone posted the uk spec on here but I cant find it now...
hmm
do you have some links to one that works on a european civic. the one i post is from USA, and if the one i have now don't work and it is from USA, i don't think this will work ether
This one is probably the best ...
http://www.ipodcarkitdirect.co.uk/Dension_Gateway_300_for_Honda
Note that it has USB & iPod & 3.5mm Phono connections - the USB cable comes with it - the iPod cable is an extra, from the same site - the 3.5mm Phono cable can be bought locally ...
The "Box" goes behind the dash, plugged into the HU, and you can run all 3 cables through the same supplied 'transit' to (for example) the central cubbyhole, behind the gearshift ...
