Hi, I just bought this Honda I went for a spin and everything was OK.
Took it home left it parked for a couple of hours and then when I went back to it to go for a ride It just won't start.
Is not completely dead but it doesn't have enough power to start.
I've used a jump start and it worked. Drove it for like 15min.switched off and when I switched on nothing happend again.I had to jump start again.
Any clues what could be the fault?
Battery or alternator?
Have you checked battery indicator to see if battery has died? Same symptoms I had and needed new battery.
The honda oem battery has an indicator on the top.
If it's the original battery it's at the end of its life.
Had the same symptoms on my 2010 2.2.
Battery indicator showed green so I just charged it.
Showed 13v before I went to work and was down to 10v by the time I had finished work (was not connected to anything)
Faulty battery, got one from cox for around £65 delivered
The battery in mine was dead after the same symptoms... to the point the used car dealer I bought it off had to jump start it on the day I handed over the cash! I, of course, got a little discount because of it.
Anyway, I used ASM Auto Recycling in Aylesbury and got myself a Bosch. It's used, sure, but they check them and charge them and are good by their word. Best part, it was only £25.
Bye bye Honda...
Does it have a hands-free phone (HFT) adaptor? These are notorious on sone Honda models for developing a fault that drains the battery overnight... Replacing the car battery may appear to bring about a repair, but it's only because the new battery has a bit more functional capacity and eventually the problem can return as the battery ages.
