21 - 33 of 33 Posts
Discussion Starter #22
About five minutes in. It shows you how to relink your keys with the immobiliser with the HDS
https://m.youtube.com/watch?v=F1smY9_1_ds
I really appreciate your precious time you sacrificed for me sir. But I've gone through this video but the error keeps popping up that I should perform system check and when I did the system check.. it comes up with the Error C-1. ,
Sent from my SM-G950F using Tapatalk
Yes sir
Dang, the car and keys really don't cope well with that. Tho I don't need to tell you that now!
Sorry pal, good luck getting it sorted.
The error says the immobiliser ecu isn’t paired.
So go into the immobi setting and try and delete the existing one and pair it again.
It’s telling you the issue.
Then try and sync your keys by using the all keys lost option.
Discussion Starter #27 (Edited)
No doubt @lightningslow you are genius. I did as you said and the screen took me to a place I will need a PCM code which I didn't have I installed Honda HDS 3.102.029 and I've tried two calculator password on it.. Please if you have or anybody have the Honda HDS Immo keygen, Please contact me I want to buy. I want the one that is working 100%. I will test it before I pay. because the HondaAcura Immo with winhex I bought didn't work.
Thanks everyone that guided me to this level. I really appreciate. I owe you all.
I'm happy that i'm getting there.
Discussion Starter #28
The function is locked.
I'm using Honda HDS 3.102.029
VIN: 20754
Date: 06/29/2019
Please help
Discussion Starter #30 (Edited)
You need older version of HDS for most PCM calculators to work. Version 3.015 and higher doesn't work with the calculator.
https://www.weboctopus.nl/pcm-code.php
Also that VIN is way too short!
Thank you boss, I've download HDS 3.012.033. my HIM is locked when I was trying to input the immo password. Am thinking of selling the HIM and get SPX MVCI.
As per that VIM the password generator required last five number.
Thanks sir.
Discussion Starter #31
Hi Gurus and boss in the house, Please I'm here with another dilemma. please help with the solution to the attached.
You have either blown fuse or an air flow sensor loom opened. Make sure the plug on top of the air box is plugged in and check all the fuses.
Then perform static learning of the ishift.
Discussion Starter #33
I trust you! Thanks boss
21 - 33 of 33 Posts
