Hi All,
feedback for the footwell lights.
received them very quickly, packaging good.
once opened, instructions where good, I waiting until I’d managed to get hold of a metal coat hanger, as there isn’t much room behind the dash to feed the LEDs from drivers side to passenger side.
installation was pretty easy, although working in a car footwell is never enjoyable.
you’ll need to use cable ties and I found having some double sided number plate time a good way of ensuring the LEDs affixed to the plastic, they do have adhesion but it was very cold today, so using the double sided number plate tape made the. Installation much easier knowing the LEDs would definitely adhere to the plastic.
once installed and all the trim replaced the LEDs work well and the option to select your desired colour is great, plus you can just leave the control under the floating dash section, so you don’t loose it.
the light spread is really good and for 30mins work, at £43 is a fraction of the cost of the Honda option which doesn’t allow you to change colour.
Just ensure you have a 10mm fitting available, dry weather, a metal coat hanger and probably some high adhesive double sided tape especially in the current weather and you’ll be sorted.
many thanks chaps for a great aftermarket product.
Kindest Regards
Darren
Kindest Regards
Darren
