I recently replaced my Honda connect stereo with a JVC KW-M560BT Carplay enabled unit. I found multiple threads with bits of information, so I've decided to create this post to help others out there.
I had a Honda connect unit with built in Garmin Nav, my car is a 2015 facelift. I can confirm there is access to some menus, the time has automatically synced with the new car radio, so there is no concern about having mismatched time and i still have some Mpg information.
I've been able to retain my reversing camera and steering wheel controls. I no longer have phone control buttons on the steering wheel, the USB ports and HDMI in the armrest are now redundant. I now have a USB mounted under the heater controls, i didn't feel it was worth the cost to retain the original USB ports.
My initial impressions are it's well worth the update, the aftermarket unit is so much faster, smoother and Carplay is brilliant.
Purchase list:
Connects 2 fascia and wiring adapters - Connects2 - Vehicle Integration
24 Pin camera retention interface - ATD CRC-27070 Rear Reverse Camera Retention Cable For Honda i-MID OEM 24 Pin Connector
Observations:
I found the following useful:
Installation Vids:
Connects 2 instruction video -
Installation guidance in a pre-face civic -
Civinfo threads:
www.civinfo.com
Pics:
Original unit, Double din mounted in existing fascia and fitted into the car. I will take better pictures during the day.
Happy to answer any questions.
Purchase list:
Observations:
- Additional wiring in connects 2 kit for Bluetooth module, given my car had the Honda connect, there is no independent Bluetooth module. For this reason you will loose the phone buttons, i will attempt to get hold of a pre-facelift Bluetooth module and connect it to see whether this restore the phone control buttons.
- fascia in the Connects 2 kit is the same dimensions as the original Honda connects fascia. I kept my original fascia as it matches my interior better and there was no need to transfer over vents, hazard buttons etc.
Installation Vids:
Civinfo threads:
Head Unit Upgrade on a 2016 Civic SR
Did anyone make any headway on this? Xenor, where did your quest land you? What did you end up purchasing, parts and all, if you succeeded? I am on this quest as of now! Please do keep us up to date on how your doing!! Is your facelifted or not?
Pics:
