1 - 19 of 19 Posts
Honda File Share - 9G Service Manual Excerpts
As you may have seen in a few of my other threads, I've been collecting service bulletins et al wherever I find them, Primarily for my own future reference and benefit, but also so that I can share them with others when needed.
As I've got a fair few different bits now, and the collection grows whenever I have the chance, I thought I'd pop the link here so you can browse at your leisure and perhaps find out something new.
https://drive.google.com/drive/folders/1weWkjooZ265OQqZTIBGn2nZrY-QIVJ19?usp=sharing
Thus far, I've uploaded / Am uploading:
- The Safety Alerts camsam application, credit to @Bog
- The RC8 Files & Bulletin
- Various other Honda Connect RC Versions and documents
- All Honda Manuals that I've found on the site
- The FAT32 Formatting tool that can be used to FAT32 Format drives above 32GB For use with Honda Connect units.
- Service bulletin for Wind Noise in 9G
- Service document for Tailgate spoiler installation, credit to @Xa4cornelis
- Civinfo Wiki XML Export
If you have anything that could be useful, let me know and it can be uploaded - I have plenty of space!
I've split up the service menu snips into folders. There is quite a bit of information on trim deconstruction for the interior / exterior, so you can go forth with confidence and no broken clips (You hope :D )
I've also grabbed the wiring diagrams; I should have everything - Lighting, Car, CAN, Audio et al - Everything I've grabbed thus far applies to the SE+ 2016 / 2017 9G, So the majority should apply across the grades:- I've taken separate wiring diagrams for the various audio circuits.
Edit: I've also added a number of the most relevant service bulletins too.
For those using (Or attempting to use) Mirrorlink, there is a quite useful powerpoint outlining operation and applications that are known to work with the 9G Connect.
Hi Haltamer,
I have this file:
Honda S2000 (00-03) Service Manual.pdf
I can't remeber where it came from.
Looks like a digitalized copy of the SM.
Would it be OK to upload it?
Rec
I uploaded 4 files to webtransfer (255 MB)
But I am not allowed to PM you, neither to post links...
Maybe in the next days I will get permissions.
Rec
Hi Haltamer,
Rec
I have uploaded several files, and PMd you the links.
But today I noticed that I have "Sent msgs 0" (!?)
Did you receive my PMs?
Rec
Discussion Starter #16
Bump!
I've added a lot to this the other day, see "26 06 19 Unsorted..."
There's a few more engine servicing items for the L13 / R18, as well as interior trim and some very interesting ancilliary documents that go into the function and operation of some of the more mechanically interesting parts of the car. (L13 VTEC, AHA, VSA) etc.
1 - 19 of 19 Posts
