Is there a way to get Hondata to inject fuel during over-run a section of the rev range, for example 3000 to 7500rpm.
I know that fuel is totally cut normally on over-run and wondered if there was a way i could use Hondata to add fuel on over-run!
I really struggle to heel and toe... I just cant get my heal round enough to hit the accelerator unless I have the brakes really depressed which is rare. Sorry, doesn't help with your question Jonathan
Clutch pedal guru
Can't you download the software and have a look in the settings tables?
The main reason is i believe touring cars do it to help with throttle response, and i find it is a little slow sometimes to pick up, so thought this would help.
Even if it dosnt help with the throttle response, if it pops a few flames then i would do it anyway!
Leave the fuel overrun alone. You will only foul your plugs.
Touring cars will do it to keep the turbo spinning I bet, bit like antilag.
